Hydraulics Disable
Hi,
(as Joystick was faulty and repaired) but after this i'm facing the problem in hydraulic function which is all hydraulic functions stops after some time later. I've tried to interchange the drive controller with hydraulic but the truck shows different errors so i think there is need to synchronize the controllers with the truck via menu. Someone told me that activate the service menu function with switch key and go the "STD Parameters" and press double arrow button (which in second position on right side of display) "STD Truck" again press double arrow button then press most right button (P 1-2) then save with double arrow button then restart the truck but after this unfortunately the side-shift and double deep extra hydraulic function is disable.
Please advice that how to get it back the both hydraulic functions on working state?
  • Posted 11 Jun 2020 19:08
  • By Syed
  • joined 14 May'15 - 194 messages
  • Sindh, Pakistan
swasiquehussain at gmail dot com
Esie Cortez Esie Cortez
Oxford Ct, United States
Aichi SR18A
Taylor XC300M
New - Sale & Hire
