Crank no start
The lp level warning/rack lock light is on but there is lp and as far as I can tell the rack lock switch has never had any wires hooked up to nor is there any in its vicinity I'm thinking maybe fuel pressure sensor but I can't get it started to test it
  • Posted 4 May 2020 23:57
  • By Quinton_Baker
  • joined 1 Apr'20 - 8 messages
  • Wisconsin, United States
Qbaker
Thanks man yea that was not on there correctly and the vaporizer needed a rebuild
  • Posted 6 May 2020 08:47
  • By Quinton_Baker
Qbaker
You need to make sure that you fuel hose connector is threaded on completely. There should only be a gap about the thickness of a half dollar between the coupler and the tank valve. If another tank was put on sometimes the square ring from the old tank will come out and sandwich between the coupler and the valve also not allowing the valve to open. There is a sensor on the line under the radiator cover panel.
  • Posted 6 May 2020 08:45
  • Modified 6 May 2020 08:46 by poster
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
Deborah Baker Deborah Baker
Muncie, IN, United States
