wiring diagram
I am working on this unit, and I found the glow plug fuse blown. I replaced it and tested. the glow plugs stay on all the time. When I pull the relay, the power goes out for the glow plugs. So my question is, is what powers up the relay, is there a timer, or does it work off the sensor that is in the thermostat housing? the engine is a Z15 diesel.
Thanks so much,
John
  • Posted 27 Mar 2020 04:15
  • By John_Rogers
  • joined 26 Oct'19 - 5 messages
John Rogers
Thanks sooooooo much will check out, great idea on the push button.
  • Posted 28 Mar 2020 03:51
  • By John_Rogers
John Rogers
Toyota 7FDAU50 i quess?
There is a small box under the lefthand "stepon"
Probleby couvert with dirt, the wires will by corroded.
Cheapest way is to make a pusbutton on the dasboard, and connect to the relais.
  • Posted 28 Mar 2020 02:31
  • Modified 28 Mar 2020 02:37 by poster
  • By John50
  • joined 7 Sep'19 - 153 messages
  • Netherlands
