Linde E30-1 (2012 year) Error code T220
Hello
What does the error T220 mean?
I checked almost all the connections, fuses, relays and potentiometers. Everything is fine. Could this error indicate a malfunction of the control unit?
  • Posted 18 Oct 2019 10:54
  • By Gena_Ivanov
  • joined 18 Oct'19 - 8 messages
  • Belarus
Showing items 1 - 17 of 17 results.
I found the reason for the error T220.
The problem with me was the LAC 24/11 hydraulic controller. No communication via pathfinder. After replacement, everything works.
  • Posted 17 Jan 2020 06:28
  • By tomason2
  • joined 5 Apr'15 - 53 messages
  • Poland
serwiswojnarowski@gmail.com
I have a problem with LINDE E30HL-01/600, H2X387, 2015 year
The truck stopped driving and after turning the ignition off and on, the error T220 appeared on the display. Driving and hydraulics do not work.
Fuses OK.
  • Posted 3 Jan 2020 06:22
  • Modified 9 Jan 2020 05:15 by poster
  • By tomason2
  • Poland
when you like to fix it bij you one you neet de softwere and cabless
ore foon linde
mail my it is on prifile
  • Posted 27 Oct 2019 20:56
  • Modified 27 Oct 2019 21:28 by poster
  • By michel_v
  • noord holland, Netherlands
I do not have cable and software.
  • Posted 27 Oct 2019 20:47
  • By Gena_Ivanov
  • Belarus
hef you de software and cabless for conect to de truck?????
  • Posted 27 Oct 2019 20:11
  • By michel_v
michel_v, I do not understand you.
the laptop is a pedal ?? If so, then there are two (2). You already asked about this, see above.
  • Posted 27 Oct 2019 19:41
  • By Gena_Ivanov
  • Belarus
you hef linde laptop ?
  • Posted 27 Oct 2019 19:18
  • By michel_v
No. How to reset to factory settings on this model?
  • Posted 27 Oct 2019 09:43
  • By Gena_Ivanov
  • Belarus
you hef try to zet factory seting ?
  • Posted 27 Oct 2019 08:26
  • By michel_v
two!
H2X387C01180
  • Posted 24 Oct 2019 03:54
  • By Gena_Ivanov
  • Belarus
hef you one ore 2 pendals??????
  • Posted 24 Oct 2019 03:31
  • By michel_v
seryail nr
  • Posted 24 Oct 2019 03:26
  • By michel_v
Sorry, did not understand you.
model Linde E30-1
LDC-70/11CE04
  • Posted 24 Oct 2019 03:19
  • By Gena_Ivanov
  • Belarus
whits model
and hef you laptop??
  • Posted 24 Oct 2019 02:49
  • By michel_v
  • Posted 23 Oct 2019 07:21
  • By Gena_Ivanov
  • Belarus
Thank you. Perhaps you know in which block there may be a problem?
Error T220 is visible when the LDC-70 block is disabled, does this mean that the problem is not in LDC-70?
  • Posted 23 Oct 2019 07:15
  • By Gena_Ivanov
  • Belarus
T220: Truck variant not valid.
  • Posted 20 Oct 2019 04:28
  • By Bavaros
  • joined 16 Jun'12 - 21 messages
  • xanthi, Greece
TCM FHD105Z
Hangcha FLDCXT160
