Fault with can bus
I had an accident moving backwards and broke the beacon light. This caused a short circuit. After this error code 10107 displays and stops the truck with all functions. Suggestions?
  • Posted 25 Apr 2019 03:30
  • By alexmathey
  • joined 1 Sep'16 - 34 messages
  • Santa Fe, Argentina
alexmathey@gmail.com
what is yale forklift fault code 10107
  • Posted 20 Mar 2022 09:24
  • By lito
  • joined 20 Mar'22 - 1 message
  • Turks And Caicos Islands
what is fault code 10107 in yale forklift
I already found diagrams
  • Posted 25 Apr 2019 08:57
  • By alexmathey
Wich ones are can hi and can low
  • Posted 25 Apr 2019 08:55
  • By alexmathey
Measure resistance between can hi and can low with truck shut off and battery disconnected. Should be about 60 ohms. If the resistance is good connect battery and turn on truck. measure voltage between can hi and can lo. should be about 2.5 volt. If voltage is not there or the voltage is way off replace main controller.
  • Posted 25 Apr 2019 04:54
  • By BREWSKI
Combilift Ltd
