Starts up runs good after 30 mins. dies - starts and dies.
Been working on a Toyota 7FGCU25 ser. 99358 short story, when cold starts up runs for 30 mins no problem after that forklift dies. start back up dies right away. replaced the LPG regulator. tested the distributor found signal detector was bad installed new distributor.
still have the same problem. have found that the fuel lock off is clicking on and off. and if I hold the key in the run position it will run no problem let the key go and it stalls. going to chase wires today.
any suggestions would be a help. don't want to bypass the safety devices by wiring in the fuel lock off.
  • Posted 23 Apr 2019 20:56
  • By Mich_Len
  • joined 23 Apr'19 - 2 messages
  • Michigan, United States
i looked at my ground and it seems secure tugged on wires and seems good. i am having somewhat the same issue but i had mine running for more than 30 mins and let it sit and cold start it and it wont turn over had to keep adjusting the lp reg and idle adjuster. did a full tune up, cleaned carb, and repaired some broke wires again from someone who done it. mine backfires when it stalls and relay keeps clicking without key off. is there something else im missing out of the troubleshooting?
  • Posted 25 Feb 2020 13:17
  • By JoJo
  • joined 25 Feb'20 - 2 messages
Found it to be the ground wire on the side of the engine block
  • Posted 22 Aug 2019 21:33
  • By Mich_Len
Len Galanty
Terberg RT403
SMV (Konecranes) 4538CCX4
Noblelift
Sue Tomic Sue Tomic
Terberg RT403
Noblelift
