Battery problem
Everytime I change battery the truck displays error codes 30060 or 40060 (refers to motor circuit fault or steer circuit). Why does this happen?
  • Posted 12 Apr 2019 00:00
  • By alexmathey
  • joined 1 Sep'16 - 34 messages
  • Santa Fe, Argentina
alexmathey@gmail.com
you may want to check the power supply distribution board
you'll need to hook up to the truck with a laptop and check its voltages, a newly charged battery may be causing those errors due to incorrect voltages from a faulty board.
Of course it wouldn't hurt to check the wiring and harnesses around the motors and inside the joystick areas to see if anything is wrong there.
  • Posted 12 Apr 2019 07:54
Does the error clear with key reset? I would check the wiring for short to frame.
  • Posted 12 Apr 2019 02:09
  • By BREWSKI
Oxford Ct, United States
Esie Cortez Esie Cortez
Linde Material Handling
