coil Packs
Wondering if anyone is having trouble with cam or crank sensor codes. We buy OEM parts, but dealer says we go thru more sensors than all other customers combined. Its on several different machines with the K21-25. We do service the machines and change spark plugs as recommended. Any help would be appreciated.
  • Posted 5 Apr 2019 01:29
  • By porklips
  • joined 8 Sep'16 - 5 messages
  • Minnesota, United States
if you're continuously having sensor codes coming up i would pay close attention to the wire harness and also check relays. The relays have been known to cause all sorts of issues that trigger codes that lead you down the wrong path in diagnosis. Also make sure your negative grounds are clean and tight (on the frame).
There are 2 relay boxes, one beside the fuse box and the other underneath the left step cover. I wouldn't rule out the fuse box either, i've seen the fuses work themselves out of their sockets from vibration causing issues as well. But to have sensors going bad on a single machine repeatedly is uncommon unless there is something else wrong you just havn't found yet.
  • Posted 26 Aug 2019 23:46
Installing coil packs is not a no-brainer. It is way too easy to miss the plug and slide the boot alongside the insulator. At best, you have an intermittent cylinder; at worst, a fireworks show. In either event, the truck can throw an E27 or even an E43 code.
Learned the hard way:)
  • Posted 26 Aug 2019 22:25
  • By JMLTINC
  • joined 26 Aug'19 - 2 messages
  • Tennessee, United States
Yes we know when it is a coil pack, still just wondering if people are have trouble with these sensors. They are OEM
  • Posted 2 Aug 2019 06:52
  • By porklips
Are you positive it is the sensors and not the wiring? Those motors are notorious for the cam/crank wiring failing. might pull the harness apart and ohm it out to be sure.
  • Posted 27 Jun 2019 03:03
  • By Jung_Tech
  • joined 27 Jun'19 - 3 messages
  • Missouri, United States
Was trying to find out why we are going thru so many crank and cam sensors. We can repair the problem. just was curious if other people were going thru crank and cam sensors often.
  • Posted 20 Apr 2019 00:02
  • By porklips
A bad coil on a k21-k25 can cause a crankshaft sensor code. You can start the engine and disconnect 3 of the coils to determine which coil is bad. Then connect another coil and disconnect the one previously connected. Keep going till it has run on each cylinder by itself. These engines will run on 1 cylinder. The bad one will kill the motor when it tries to run it by itself.
  • Posted 7 Apr 2019 02:03
  • By mwjski
  • joined 26 Jan'18 - 33 messages
  • Montana, United States
Nagano NUZ090D
Terberg RT223
