caterpillar 3 ton.....model bp 30 np ....serial t14e-31938
please can somebody give me the needle roller bearing in the rear axle size.......they are 4 pcs but the same sizes upper and lower, thanks
  • Posted 28 Mar 2019 07:23
  • By northstar
  • joined 16 Jun'17 - 91 messages
  • accra, Ghana
thanks Swoop223....
  • Posted 28 Mar 2019 18:49
  • By northstar
  • accra, Ghana
Not sure about the size of the needle bearing but i can give you the caterpillar part number: 91E4305100.
There is also a thrust bearing between the axle housing and steer knuckle that you may need to replace which is part number: 91E4300300.
Cat does not list any specs on the bearing sizes that i can find.
  • Posted 28 Mar 2019 16:07
Oxford Ct, United States
SMV (Konecranes) 12-1200B
Taylor TT300
USD98,500
Hyster
