Code 336
Pot reading from 10.8 down to 3.3 on analizer... customer installed. think it should start @more than.05? And go up.. is this correct? Pot installed 180*out?
  • Posted 21 Feb 2019 13:01
  • By Slsafut
  • joined 21 Feb'19 - 1 message
  • Utah, United States
In my case POT was ok, The FF switch was stuck on.- inspect the gear for POT, if it's worn out, you will get this code. luckily i had another 4500 we retired. swapped the hole handle. code never returned.
  • Posted 1 Feb 2025 02:56
  • By Rocket_420
  • joined 1 Feb'25 - 3 messages
  • Alberta, Canada
Rocket_sine
In my experience, the lift solenoid welds shut sounds crazy but try changing the solenoid
  • Posted 6 Dec 2019 23:42
  • By deanod
  • joined 10 Jul'18 - 6 messages
  • Illinois, United States
Dean Davison
Aichi SR10C1SM
JLG G12-55A
MAXAM Tire, Inc.
