Code 92-1
Looking for troubleshooting suggestions for a propane Yale, model GLC050VXNDAE083. Truck will randomly throw a code 92-1 on the display and the service engine fault light comes on. When this happens there is no response from the throttle. Normally, restarting the engine will correct the issue. This might happen once an hour or once a week. I am currently trying to find a parts/service manual for this truck, but we bought it used so I dont even have access to the menus. Does anyone have any suggestions on what I can check while I am waiting to find a manual. I appreciate it.
  • Posted 12 Feb 2019 23:36
  • By GaryT
  • joined 28 Apr'11 - 10 messages
Ramon,
Start the engine and press the throttle pedal down and push on it sideways. If code shows, bushings inside pedal assy are worn and need replacing. You will need to install a new pedal and mount. Verify all connections and wiring has not chaffed. Good Luck
  • Posted 2 Jun 2023 02:22
  • By garland_m
  • joined 16 Oct'09 - 212 messages
  • Virginia, United States
Work Hard and Fish Long
Hey gary did u ever figure out the problem. I have one with the same problem 91-2 so intermittent.
  • Posted 1 Jun 2023 07:54
  • By Ramin_Barai
  • joined 13 Nov'22 - 3 messages
Thank you, the operator had the numbers reversed on the sign-out sheet. Is this a remove and replace procedure or will the new sensor need to be calibrated?
  • Posted 13 Feb 2019 01:45
  • By GaryT
There is not a code 92-1, there is a 91-2 code. It sounds like your pedal position sensor is about to fail.
  • Posted 13 Feb 2019 00:09
  • By BREWSKI
SMV (Konecranes) 20-1200B
Toyota 02-2TD20
Prospect CT, United States
Dayton OH/Cincinnati OH, United States
Philadelphia, United States
Rob Ott Rob Ott
Executive vice president and chief commercial officer, East Penn Manufacturing
President, Logistics UK
Director of dealer development East Coast, Big Joe Forklifts
Vice president, customer, TVH Americas
Rob Ott Rob Ott
LiBiao Robotics open New Jersey office Hillsborough, NJ, United States
October 8-10, 2025 - Lucca, Italy
June 17-20, 2026 - Bangkok Thailand, Thailand
August 19-21, 2026 - Bangkok Thailand, Thailand
