mast wont raise no steering
so I checked fluid levels and they are good. I removed the pump and inspected it, all looks good. the mast wont raise and the steering is very hard im not sure what to check next, wondering if maybe control valve?
  • Posted 31 Jan 2019 01:56
  • By hani_a
  • joined 31 Jan'19 - 1 message
  • New Hampshire, United States
what about tilt and auxillary functions like sideshift?
do they work?
gotta check and see if your getting pressure up to the control valve, don't want to go taking that apart for no reason ;o)
also check your suction hose and suction filter inside the tank.
also if it has an inline filter remove that and check it.
when you try and use hydraulics does the engine change like it's loading up? can you hear any sounds like whining like fluid cavitation coming from the pump?
all sorts of things to check out ;o)
  • Posted 31 Jan 2019 13:43
  • Modified 31 Jan 2019 13:46 by poster
Muncie, IN, United States
Elwell-Parker ESI500-36
Terberg YT223
Deborah Baker Deborah Baker
