ATLET STACKER COMPUTER CODE
I had new control unit put on unit, getting code E100 and unit will not operate, need your help
  • Posted 11 Jan 2019 07:01
  • By Barth
  • joined 11 Jan'19 - 2 messages
  • Kansas, United States
When you first power up the truck it should come up to user ID, then you need to hit the "I" button twice until it states Atlet code or Authorized code, then enter the code 0002468, and this will take you into the menu tree. Then hit the "6" button until "set options" is displayed then hit "Enter" button to go into it, then you can scroll down with "8" button. If you are there and "Enter" button not working then either keypad or ribbon cable bad. Hope this helps.
  • Posted 11 Jan 2019 08:10
  • By Kirtland3
  • joined 11 Jan'19 - 19 messages
  • Colorado, United States
Donald Kirtland
I need more help; tried to go the options by pressing the ENT key, could not get into the menu
  • Posted 11 Jan 2019 07:42
  • By Barth
E100 is stating that you have a CAN Buss error. If you just installed new controller then you need to go to options and set them up correctly. Let me know if you need more help.
  • Posted 11 Jan 2019 07:05
  • By Kirtland3
Donald Kirtland
Deborah Baker Deborah Baker
