Deceleration problem
When I start using my machine it doesn't last with battery charge, it decelerates and doesn't allow lifting as if it was uncharged even when battery displays 50%. Is there any voltage level configuration I can fix? Thanks in advance!.
  • Posted 7 Nov 2018 22:34
  • By alexmathey
  • joined 1 Sep'16 - 34 messages
  • Santa Fe, Argentina
alexmathey@gmail.com
sorry for late reply look in email also when having problem make sure serial number is there as well it helps alot
  • Posted 19 Nov 2018 18:23
  • By redbull
  • joined 14 Oct'16 - 108 messages
  • Queensland, Australia
added mail to my signature, thanks man
  • Posted 14 Nov 2018 08:51
  • By alexmathey
[email address removed]
  • Posted 14 Nov 2018 08:49
  • By alexmathey
put email in your signature in your detail
  • Posted 11 Nov 2018 18:57
  • By redbull
You need to check the voltage when you loose lift. It sounds like one or more of your batteries are failing.
  • Posted 8 Nov 2018 00:16
  • By BREWSKI
