J50XN Code 9004 E-Hyd Enable
Hello Everyone,
So the code is for a short to batt positive for the E-Hyd Enable according to the book. The troubleshooting steps say to check the terminals at the relay and replace as necessary.
The thing is I can't locate the relay. The book even has a page that says where it is and it is not in that location. Any help on what the issue may be or the location of the relay are greatly appreciated, thank you.
Hyster J50XN electric 4K Forklift
  • Posted 8 Aug 2018 22:46
  • By Natedog
  • joined 8 Aug'18 - 1 message
  • New Jersey, United States
Nate,
The relay should be located on the right side of the dash behind the plastic cover. The other location is for three wheel lifts, relay is located under the floor plate on the left side at the fuse box. Need to make sure all connections are good from relay to VSM. Good Luck.
  • Posted 16 Apr 2024 22:18
  • By Fishmech
  • Virginia, United States
Hi , did you figure out the code 9004, thank you
  • Posted 2 Apr 2024 08:21
  • By david_li
  • joined 2 Apr'24 - 1 message
  • British Columbia, Canada
Hi, I have the same problem - error 9004. I replaced the relay. it didn't help. Have you made progress with it?
  • Posted 27 Nov 2023 22:46
  • By Sergej
  • joined 27 Mar'20 - 1 message
  • okres Trnavsky, Slovakia
Sue Tomic Sue Tomic
Sue Tomic Sue Tomic
