hystamatic transmission
Hi Guys...... i have hyster fork lift 5.5 ton. fitted with Hystamatic transmission 113584... where can i find charging pump for this transmission plssssss help me
  • Posted 12 Jun 2008 20:03
  • By allan_l
  • joined 24 Sep'07 - 32 messages
  • united arab emirates, United Arab Emirates
Thanks guys i mannaged to get charging pump for my bad luck torque converter is dead i have to replace that now i think it is T18 TRANSMISSION do you have catalg copy for T 18 TRANSMISSION please let me know or prat number of torque converter bye good day
  • Posted 27 Jun 2008 04:04
  • By allan_l
Look at the transmission control valve. There will be a machined surface on which the control valve mounts. On one corner of that surface will be the transmission serial number. Any OEM dealer should be able to get you the correct charge pump from that number
  • Posted 27 Jun 2008 03:45
  • By killer_rabbit
  • joined 20 May'08 - 7 messages
  • Minnesota, United States
hi...it is fitted with perkins engine 4 cyl no other details.... thanks
  • Posted 13 Jun 2008 15:06
  • By allan_l
What is the Model and Seriel number?
  • Posted 13 Jun 2008 07:41
  • By roadrat
  • joined 24 Jan'08 - 186 messages
Terberg RT403
Ncn 110TH
Ncn 110TH 2015
