NO SPARK
UNIT HAS A MITS 4G64 TIER 1. ONLY SEE A CRANK SENSOR AND COIL. DIST IS ONLY TO DISTRIBUTE SPARK. NO WIRES HOOKED TO IT AT ALL.
TIMING GOOD. NO SPARK FROM COIL.
HAD INT HOT NO START.
GOT WORSE. FIGURED IT WAS COIL OR CRANK SENSOR. CHANGED BOTH. NO SPARK. COIL HAS SWITCHED 12V AND GROUND
  • Posted 13 Dec 2017 06:31
  • By TKOforklift
  • joined 24 Nov'07 - 30 messages
  • British Columbia, Canada
TKO Forklift and Equipment Repairs
Kamloops BC
250-819-6575
tkoforkliftservice@gmail.com
Had this exact problem, i changed the whole distributor and it fixed it. Customer had tryed cranking it over and killed the battery and wrecked the module in the distributor, make sure it has a good battery as well.
  • Posted 24 Dec 2017 08:06
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
