Code E-36
I have a unit that is displaying the code of e-36 i know that that is a lpg low presh sensor code. I checked the LPG presh coming out of the vaporizer and it was about 34KPA. I do not have a laptop to hook up to the unit, and it does not have the OBDII conector on the truck. what could be the issue?
  • Posted 13 Oct 2017 06:09
  • By sbhbrett
  • joined 18 Mar'16 - 17 messages
Check your inlet screen on the mixer where the propane comes in from the vaporizor..there is a small screen that can get clogged woth debris...be careful,it is held in with a small clip and the screen can rip easily
  • Posted 1 Dec 2017 04:20
  • By kevin_t
DTC E36--LPG Fuel Pressure sensor diagnostic result signal.
Check fuel pressure with Diagnozer. If pressure is reading low then retest pressures using actual gauges to confirm pressure. If actually low, check fuel lock and filter (clean).
If no reading, check failed main C or EGI relay, blown fuse, broken wire at the sensor, blocked filter screen in the injector holder.
  • Posted 1 Dec 2017 01:31
  • By Bacon123
  • joined 25 Jul'17 - 10 messages
JCB 533-105
Nagano NUL120-6
Esie Cortez Esie Cortez
JCB 533-105
Nagano NUL120-6
