Event code 128
truck has no drive forward or rev altho the alarm sounds when rev is selected. Hydraulics very very slow can hear the pump kick in when levers operate then faults, has event code 128, can anyone help ?, thanks in advance
  • Posted 14 Sep 2017 16:39
  • By jay_dee
  • joined 2 Oct'14 - 21 messages
  • New South Wales, Australia
2 heads are better than 1
Change lift motor encoder.
  • Posted 2 Mar 2018 16:09
  • By techno_nz
  • Canterbury, New Zealand
Hello friends, I'm working on an sc5245-40. Getting this 128 and 230 code. Any help is appreciated
  • Posted 26 Jan 2018 07:28
  • By sako_k
  • joined 12 Mar'14 - 17 messages
Thanks popeye, found that the lift pump motor encoder bearing failed, remove lift pump and motor stripped and fitted new encoder bearing refitted everything and boom happy days. Awkward job to do as the whole assembly is blimen heavy.
  • Posted 22 Sep 2017 18:19
  • By jay_dee
Check your battery. If it is 36 volt battery and it drops below 31 when you move levers and pumps kick in that's it.
  • Posted 16 Sep 2017 09:44
  • By popeye
Crown CG33P5
Nagano NUL120-6
Crown CG33P5
Nagano NUL120-6
