BT Error 125
The company I work for has a Toyota BT RRE 160M Forklift, No, 6024335/2008 model.
We have recently had issues with the forklift just stopping suddenly with the error 125, it goes into slow mode, and no sterring controls, after a while of turning it off and on it starts up again until it happens again.
Is there somewhere I can get the definition of the error code in pdf form or any actually so we can get it fixed.
Thank-you all.
  • Posted 22 Aug 2017 22:55
  • Modified 22 Aug 2017 22:59 by poster
  • By Matty
  • joined 22 Aug'17 - 1 message
  • Victoria, Australia
E125 will be the steer tacho under the steering wheel.
The truck will throw a critical stop & lock the parking brake on when it sees a steering fault like this.
Order a replacement steer tacho, line the grub screw up with the flat on the tacho shaft & thread lock the small grub screw on the joint.
A steer tacho on this is simple plug & play replacement - just unplug battery while you work.
  • Posted 23 Aug 2017 04:15
  • By Forkingabout
  • england, United Kingdom
Mitsubishi FD200
Terberg RT223
