code 65
Hi, we put the drive motor and when trying to start the unit, show code 65, some people tell me can be the driver (it´s the GE gray box)
it is true.
regards
  • Posted 9 Aug 2017 21:35
  • By Dokku
  • joined 3 Nov'16 - 38 messages
  • Nuevo Leon, Mexico
You know, if they connected the traction motor with the wrong wires, this has repercussions on the controller, we checked and the technician connected the wires motor bad and, yes the controller is damaged.
Thanks for your help, now I need buy a new or remanufactured
  • Posted 11 Aug 2017 04:06
  • By Dokku
There could be a problem with the controller.
  • Posted 10 Aug 2017 00:02
  • By BREWSKI
ok, I check, if this are ok, what more can make this code, it´s only cause.
thanks I check
  • Posted 9 Aug 2017 23:42
  • By Dokku
65 is normally a shorted line contactor. Check resistance in the line contactor coil.
  • Posted 9 Aug 2017 22:43
  • By BREWSKI
Terberg YT220
TCM FHD105Z
Lift Tek Elecar
