YALE GLP50MJ V2514 SERIES E813A ENGINE STOP AFTER 35s
Hi i have a trouble with this yale, engine GM4,3 Engine burns a lot of oil so we repair the cylinder head. Now when engine start working only 35 seconds and stops, start again and working 35 seconds stops again and again 35 seconds...somebody can helpme where is problem, some idea???? when connect computer to impco module there is no errors...
  • Posted 25 Jul 2017 22:42
  • By tom_i
  • joined 24 Mar'15 - 6 messages
  • Lublin, Poland
problem solved, one cable from sensor oil pressure in engine was disconnected, impco module after 35 sec stop engine, i saw this error but only when engine stop, when engine working there was no error
  • Posted 12 Sep 2017 16:09
  • By tom_i
  • Lublin, Poland
Check the voltage at the LP lockoff valve. see if the voltage is dropping before the truck dies. May be an overheat sensor.
  • Posted 1 Aug 2017 04:37
  • By BREWSKI
when engine stop resound long sound, but oil pressure is ok because when engine stop in impco software show error pressure oil, clear error start engine oil pressure ok,
  • Posted 31 Jul 2017 16:22
  • Modified 31 Jul 2017 16:26 by poster
  • By tom_i
  • Lublin, Poland
Sounds like a high temp or low oil pressure shut down.
  • Posted 29 Jul 2017 07:23
  • By BREWSKI
