Back up Beeper wiring
I have an SLT30 S/N 46603d30394
Back up beeper doesn't work, chased wires from beeper, power wire goes into a connector with other wires, on the other side of connector where beeper wire goes, there is nothing, no wire, no pin. Can't find a loose hanging wire or anything and custy says hasnt' worked in at least 3 years...so question is where is the power wire come from if i'm gonna try to rerun it is off the direction switch? any help is appreciated!
Thanks Dudes and Dudettes
  • Posted 20 Jun 2017 00:43
  • Modified 20 Jun 2017 00:44 by poster
  • By ryan_t
  • joined 12 Apr'17 - 28 messages
  • Newfoundland and Labrador, Canada
Yoooooo!
Thanks for the info and help, goin to look at machine this morning, hopefully all goes well, wiring is the bane of my existence , rather be turning a wrench haha
  • Posted 20 Jun 2017 20:55
  • By ryan_t
I am not sure on that model. We have a diagram in our inventory. That is how I found the connections. I would think they would be under the cover just under the seat deck.
  • Posted 20 Jun 2017 05:46
  • By BREWSKI
Ok cool, so it's the power wire which is 26 labeled on wire, where are fuses on machine? Seems like a dead brain question but would rather know before i went to look at machine keep labour times down and economy good! haha
  • Posted 20 Jun 2017 04:42
  • By ryan_t
Yoooooo!
Factory install added a second reverse switch. This switch is fed Negative from the #8 terminal on the controller which is the reverse input from the directional switch. Positive is directly connected through fuse #7.
  • Posted 20 Jun 2017 01:37
  • By BREWSKI
Michel Denis Michel Denis
