code E-23
Code E-23 on dash. Dash lights blink on/off. Not sure if related. What is the code/possible checks? Unit starts and runs fine. Visually everything looks in order. Fluids are good. Any help is greatly appreciated. Thanks.
  • Posted 14 Jun 2017 07:35
  • By Louis
  • joined 7 Aug'10 - 19 messages
E-23 usually indicates a problem with the throttle sensor. Check for good connection, or moisture in the plug connection. Check voltage output of sensor by back-probing harness connector.
  • Posted 15 Jun 2017 21:39
  • By lifterfixer
  • joined 15 Jun'17 - 6 messages
TCM FHD105Z
Factory Cat MICROMAG20D
TCM FHD105Z
Combilift Ltd
