error code
I have a message saying accelerator sensor error
crown RC5530C-30
  • Posted 4 Apr 2017 02:19
  • Modified 4 Apr 2017 02:20 by poster
  • By delga76
  • joined 20 Oct'16 - 22 messages
thanks
Thanks, do all the tests but I did a more thorough check and detect that the problem was access 3
  • Posted 13 Apr 2017 01:52
  • By delga76
thanks
Easy.
Seen that a lot.
If the truck operates then when plugging it sometimes shows that replace the F/R sensor. Part # 140747.
If it shows it all the time then go into the service menu and go to A2.4.1 this will show your forward switch move the control handle from natural to forward the number shown should change from a 0 to a 1 move the handle several times it should change every time 0 in the neutral position and 1 with the forward command.
Then the same thing for the reverse. A2.4.2 should be the same response 0 and 1.
Not changing to 0 and 1 replace the same sensor as above.
If it is showing the right numbers then calibrate the traction pot. C1.1 if calibration fails then replace pot.
  • Posted 6 Apr 2017 09:49
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
Mitsubishi Logisnext FD25T5M
Taylor TT300
USD98,500
Taylor TT300
USD98,500
Sue Tomic Sue Tomic
