Linde (& Baker) E15:
Technical Information
I have just bought a Linde E15 year of manufacture 1989, it has a problem with travel which seems to be linked to the steering. Are there micro switches on the steering. When stationary the steering is very stiff.
Does anyone have a workshop, service and/or parts manual for sale or know where I may get one. Thanks
  • Posted 10 Dec 2020 23:36
  • Discussion started by Bob_Morris
Bobisok
The first number is a 3. Like I said 324......
It is a 1989 machine. Put the directional switch in forward and try turning all the way to the left-Does the machine still move? Now turn the wheel all the way to the right Will it move?
  • Posted 23 Dec 2020 23:42
  • Reply by duodeluxe
  • United States
duodeluxe
Sorry for the late reply. Thanks a lot for your help with this. Much appreciated.
  • Posted 23 Dec 2020 22:39
  • Reply by Bob_Morris
Bobisok
Thanks a lot for your help it's much appreciated, will take a look. Thanks again !
  • Posted 23 Dec 2020 22:38
Bobisok
If steering is tight in stationary, possible prob is in the pressure switch. switch is locate near orbitrol. 2 wire goes there, im sure you find it. if it doesent work, pump motor doesent start when you rotate steering wheel. micros top of the back tire just give info to logic what is back tire position. example if one micro broke, steering get stiff when u turn right and so on.....check motor brushes and clean the motor with pressure air too. sorry my bad english.
  • Posted 23 Dec 2020 22:34
  • Modified 23 Dec 2020 22:36 by poster
  • Reply by Justus
  • Finland
My guess is that the serial # starts with 324..... If so, you most likely have an issue with the steering switch(es) which are located in the rear compartment right above the steer axle.
  • Posted 16 Dec 2020 23:51
  • United States
duodeluxe
Sorry don't know what that is but it doesn't look like a Linde serial number it should start with something on the lines of 91x
  • Posted 14 Dec 2020 05:20
  • Reply by lifter01
Serial number: 824903018615 there's a mark across the first number so it may be a 3 instead of an 8
  • Posted 12 Dec 2020 09:58
Bobisok
Post the serial number as E15 means very little
  • Posted 12 Dec 2020 08:02
  • Reply by lifter01
TCM FD115-3
Hangcha CPYD25XW71F-JC
Flesherton, Ontario, Canada
Your Focus
