Technical Information
I have just bought a Linde E15 year of manufacture 1989, it has a problem with travel which seems to be linked to the steering. Are there micro switches on the steering. When stationary the steering is very stiff.
Does anyone have a workshop, service and/or parts manual for sale or know where I may get one. Thanks
  • Posted 10 Dec 2020 23:36
  • By Bob_Morris
  • joined 10 Dec'20 - 4 messages
Bobisok
The first number is a 3. Like I said 324......
It is a 1989 machine. Put the directional switch in forward and try turning all the way to the left-Does the machine still move? Now turn the wheel all the way to the right Will it move?
  • Posted 23 Dec 2020 23:42
  • By duodeluxe
  • United States
duodeluxe
Sorry for the late reply. Thanks a lot for your help with this. Much appreciated.
  • Posted 23 Dec 2020 22:39
  • By Bob_Morris
Bobisok
Thanks a lot for your help it's much appreciated, will take a look. Thanks again !
  • Posted 23 Dec 2020 22:38
  • By Bob_Morris
Bobisok
If steering is tight in stationary, possible prob is in the pressure switch. switch is locate near orbitrol. 2 wire goes there, im sure you find it. if it doesent work, pump motor doesent start when you rotate steering wheel. micros top of the back tire just give info to logic what is back tire position. example if one micro broke, steering get stiff when u turn right and so on.....check motor brushes and clean the motor with pressure air too. sorry my bad english.
  • Posted 23 Dec 2020 22:34
  • Modified 23 Dec 2020 22:36 by poster
  • By Justus
  • joined 23 Aug'20 - 37 messages
  • Finland
My guess is that the serial # starts with 324..... If so, you most likely have an issue with the steering switch(es) which are located in the rear compartment right above the steer axle.
  • Posted 16 Dec 2020 23:51
  • By duodeluxe
  • United States
duodeluxe
Sorry don't know what that is but it doesn't look like a Linde serial number it should start with something on the lines of 91x
  • Posted 14 Dec 2020 05:20
  • By lifter01
  • joined 4 Jul'09 - 465 messages
Serial number: 824903018615 there's a mark across the first number so it may be a 3 instead of an 8
  • Posted 12 Dec 2020 09:58
  • By Bob_Morris
Bobisok
Post the serial number as E15 means very little
  • Posted 12 Dec 2020 08:02
  • By lifter01
UN Forklift FBRP15NQZ2
Taylor T520M
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
Tapio Rummukainen Tapio Rummukainen
President, Logisnext Europe
Chief operating officer, Clark Material Handling Company
Lithium battery sales manager, BSL Battery
Chief executive officer, Corvus Robotics
ProMat picks up two awards for 2025 event Los Angeles, CA, United States
Venus is the only planet in our solar system that spins in a clockwise direction. One day on Venus is 243 Earth days long, which is even longer than its year, which takes only 225 Earth days.
