TB45 Nissan Motor
Anyone know the Published LPG Fuel pressure on Nikki regulator to the injectors? Or have a manual on it?
  • Posted 15 Feb 2013 17:17
  • By russell_l
  • joined 7 Sep'09 - 32 messages
  • Queensland, Australia
rusty
GP40KL DUAL FUEL T29C50018 TB45-069080
  • Posted 20 Feb 2013 10:10
  • By russell_l
More info on this would help. Supply a model and serial number. Dual fuel ect.
  • Posted 20 Feb 2013 09:59
  • By RCAV8TOR
  • Alabama, United States
We have contemplated this but we have to fit new accel pedal & cable, and unsure of the relationship of the ignition system to the injector system, we got a new regulator so we will keep going on it.
  • Posted 20 Feb 2013 08:34
  • By russell_l
rusty
I dont like those systems, change the entire fuel system to impco, and be done w/it
  • Posted 18 Feb 2013 21:36
  • By 7777
Kevin, thanks I really wanted to see a book with it I have the Cat manuals but it does no say the pressure. We have a bad starting problem it cranks for about 30 sec before firing and has a history over the last 12 months of intermittent bad running months apart, no faults coming on the dash light.
  • Posted 18 Feb 2013 10:37
  • By russell_l
rusty
The pressure is adjustable on the front is a cover with tamper proof screws under it is a lock nut and a bolt if you loosen the lock nut and turn the bolt out that lowers the PSI in Raises it
  • Posted 18 Feb 2013 09:40
  • By kevin_t
Hi we had 8-9 psi so fitted a new one tested at 11 psi so hence the question? email russell at bfts dot com dot au
  • Posted 18 Feb 2013 09:36
  • By russell_l
rusty
On the NIKKI LP Fuel system the Pressure coming out of the regulator should be about 4.5-5.5 PSI on the TB45 this can be measured on the top of the regulator,is a 17mm hex on top take it out and put a pressure guage in this port and check your PSI running and under a load(tilt Bypass)......also if oyu put a email in your profile someone might have info to share with you....
  • Posted 15 Feb 2013 21:12
  • By kevin_t
Muncie, IN, United States
Deborah Baker Deborah Baker
Hawker Powersource, Inc.
