Sumitomo fb15p error code
Sumitomo yale 41-fb15p VII error code-48, need a manual,
no movement.
any help
  • Posted 3 Mar 2013 18:08
  • Modified 3 Mar 2013 18:09 by poster
  • By alexandr_k
  • joined 6 Dec'11 - 197 messages
  • Ukraine, Ukraine
thanks to all, I understand everything.
  • Posted 5 Mar 2013 04:33
  • By alexandr_k
  • Ukraine, Ukraine
I'm not familiar with this truck model , the code would sugest that the power system is an EV - 100 system, and you may have a malfunction of the direction contacts, check them for slow operation and possible welding,
The code would sugest that voltage at T2 main power terminal is less than 12% of battery voltage you should check D3 diode for short circuit or the suppressor that is mounted across it.
Regards Titus
  • Posted 5 Mar 2013 00:13
  • By Titus
  • joined 6 Jul'10 - 185 messages
Taylor TX330S
USD159,500
Elwell-Parker ESI500-36
