Stuck in reach and retract mode
forward and reverse works normal, but has no lift. will only extend and retract. Lamp indicator for reach and retract is lift and will not change. Sequence button was tested and checks ok.
  • Posted 19 Jul 2007 03:58
  • By albert_h
  • joined 22 Aug'06 - 59 messages
Hi, where are these cards?
  • Posted 14 Mar 2018 09:55
  • By forktime
  • joined 22 Dec'17 - 31 messages
  • Alberta, Canada
Thanks everbody for the help. Problem solved, found a short in one of the card slots inside the sequence box. thanks again!
  • Posted 24 Jul 2007 00:03
  • By albert_h
I would say it could be both lift interupt and the multi-function switches. The truck could have more than one problem. It could also be a loose or bad conection at the box that hold the cards that operate the hydraulic functions, broken wiring to the sequencing switch ( the push button switch on the handle),or the sequencing switch wired incorrectly. The wires to the sequencing switch breaking inside the insulation where the control handle rotates up, down, right, and left is a common problem on these trucks.
  • Posted 22 Jul 2007 13:28
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Check the MFS1 and MFS2 switches. Make sure they are operating properly. If either one is activated,the hydralic functions won't change.
  • Posted 19 Jul 2007 11:58
  • By Truck_Tech
  • United States
Crown WP302020
Maxlion FD50T
Libiao Robotics
Crown WP302020
Maxlion FD50T
Libiao Robotics
