Still RX 50-15
Help me pls.
when striking on accelerator forklift goes but slowly.
Errors no
  • Posted 7 Oct 2010 16:53
  • By valeriy_v
  • joined 25 Aug'10 - 15 messages
  • kaliningrad, Russian Federation
Hi friend,
Have you try to access error list through address service?. generally show an error when a breakdown occur, and what about the parameters of speed limitation?.
Also check the encoder of traction motor, there is a service message for encoder wire break, but if encoder is broken the truck hardly move.
Regards
  • Posted 8 Oct 2010 03:56
  • Modified 8 Oct 2010 03:58 by poster
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Dear nacsand_n.
sensor changed, result no
  • Posted 7 Oct 2010 20:06
  • By valeriy_v
Hello Valeriy,
Are you sure there is no faults?, have you try to access to fault list?. If so, probably must to check steer sensor mounted on hidraulic motor(revolution sensor) in the back of the truck. Usually break the screw in the gear assembly of steer hidraulic motor.
Regards
  • Posted 7 Oct 2010 19:35
  • By nacsand_n
  • Madrid, Spain
Manitou MH25-4
Linde C4230TL5
Bolzoni SpA (Group HQ)
