still R 70-20
Hello everyone,
I was wondering of there''s anybody who has the same trouble with a still r 70-20.
I will explain what the problem are.
when you drive slow (theres no difference between forward or backward) and you do lift or tilt at the same time the truck,goes a short time faster drive.
Its of course very unsafe and dangerous.
is there anyone who have suggestions what kind of problem this is.
avery idee or suggestion are welcome.
thanks anyw
  • Posted 21 Jul 2011 06:25
  • By co_t
  • joined 10 Oct'10 - 29 messages
  • aan den lJssel, Netherlands
marco_rens@hotmail.com
Yes thanks everyone i place new batteries and problem are gone.
thanks
  • Posted 23 Aug 2011 07:11
  • By co_t
It sounds to me like Andrew was right. The batteries are off. So if you were to replace them, I am confident the problem will go away.
  • Posted 23 Aug 2011 06:25
  • By ForkLifted
  • joined 23 Aug'11 - 7 messages
  • Utah, United States
I know this post is quite old but here goes ignore the batteries I assume the truck is a geny start model so go for the basics and work up ,set up the potentiometers on the foot pedal and lift. should be 4.2 -5 volts at rest depending on model up to 8.5- 9 on full stroke. However the most likely cause is either tachogen in end of motor or current censor in the cable between motor and gen.Hope this helps
  • Posted 12 Aug 2011 04:24
  • By daryl_j
  • joined 12 Sep'09 - 46 messages
  • manchester, United Kingdom
thanks for replay my post andrew,
i have replace both batterys ,but the problem is still there.
  • Posted 2 Aug 2011 07:02
  • By co_t
Try replacing both batterys, more than likely one is dead or as good as dead
  • Posted 31 Jul 2011 20:54
  • By andrew_k
  • joined 17 Mar'07 - 339 messages
  • England, United Kingdom
Elwell-Parker ESI500-36
Terberg RT403
Terberg RT403
Terberg RT403
REPOWERTEK Inc
