STILL EXU 20 AC traction , lifting problem
Hello everybody.The truck does not move or lifts.The led in the controller flahes two times.Only the horn is working.Any idea what maybe wrong?
Thank you
  • Posted 10 Feb 2012 21:21
  • By Touristas
  • joined 14 Jan'12 - 30 messages
  • GREECE, Greece
Thank you very much for your answers. I will check them and i will get back to you
  • Posted 15 Feb 2012 19:40
  • By Touristas
  • GREECE, Greece
Hi Mate
Have not worked on many still trucks but one thing i learnt on this forum thanks to engineers here is that some of these still use a display which hold a small battery which when goes flat can cause problems. If this has one of these displays check the battery in the back of the display.
  • Posted 15 Feb 2012 05:47
  • By elektrodrive
enquiries@elektrodrive.co.uk
Hello
Is it main contactor closed or not?
Is it wiring ok or not?
What are you see on vehicle?
Are you have 24v battery supply everywhere you need?
Check please
  • Posted 14 Feb 2012 06:27
  • By nemanja_k
  • serbia, Serbia
