Toyota 7FBE-20:
Steering problem
Hi. I have 7fbe20 steering is not working at all and no error is shown. What could be the problem
Seems like no current is going to the steering pump but even when I press the hydraulic function steering also lot works
All functions are working move front rear hydraulic ect
  • Posted 3 Dec 2022 20:35
  • Discussion started by marantonious
  • kuwait, Kuwait
Marc ANTONIOUS
Right has one hydraulic pump
And one steering Valve
  • Posted 12 Dec 2022 20:27
  • Reply by marantonious
  • kuwait, Kuwait
Marc ANTONIOUS
You cannot be working on a three wheeled 7 FBE 20? Surely your working on a 4 wheeled 7 series?
It's the same pump, it only has one hydraulic pump.
It was steering pump. Not hydraulic main pump
Normal all function was ok except the steering
  • Posted 12 Dec 2022 18:12
  • kuwait, Kuwait
Marc ANTONIOUS
That's odd? Pump doesn't generate power it simply creates a flow, it's the resistance to that flow that creates the pressure and if it created enough flow to operate your lift/tilt/side shift then you'd have to say your pump is fine.
Thank app of you for the support
The pb is the pump itself
Couldn't generate the enough power
I replaced with new and working perfectly now
  • Posted 12 Dec 2022 16:50
  • kuwait, Kuwait
Marc ANTONIOUS
Sorry for that, i was mistaken with the 7FB18, 4wheel.
  • Posted 11 Dec 2022 21:59
  • Reply by John
  • Netherlands
johnengels2@hotmail.com
Surely the 7FBE is AC motor and not DC? Faulty steer sensor, bottom left hand side on steering orbitrol unit.
Mostly the pumpmotor is the problem, check for insulation resistence and brushes, there can be a lot of brushdust inside.
If you are shure the pompmotor is oke then check the PS Controller, situated left side next to battery.
The Transistor will be broken, and DC/SD board will be broken to.
  • Posted 6 Dec 2022 08:20
  • Reply by John
  • Netherlands
Louisville, KY, United States
Dubuque, IA, United States
