Steering not always responding to steering wheel input.
Just asking to be sure I'm on the right track. Looked at a Hyster 120ft the other day that would sometimes turn and sometimes not checked hydro fluid was full no signs of leaks. My guess is the steering valve needs to be replaced. any one have any suggestions other thoughts.
  • Posted 7 Jan 2023 01:54
  • By Royce_Yeomans
  • joined 7 Jan'23 - 1 message
Royce,
Check hydraulic fluid condition along with filter. Turn steer wheel full right and hold for 10 seconds while engine is running. Do the same for full left. Test steering. There is a priority valve in the system that may start sticking. When the steering fades or stops working, does raising the RPMs on the engine help? If so suspect pump or steer valve. You can check secondary pump pressure at hydraulic tilt valve. Should read about 2300 pounds. Good Luck
  • Posted 8 Jan 2023 00:03
  • By garland_m
  • joined 16 Oct'09 - 213 messages
  • Virginia, United States
Work Hard and Fish Long
Terberg YT223
Ice 28INCH-AUTO-SCRUBBER
USD8,350
Hawker Powersource, Inc.
Sue Tomic Sue Tomic
Terberg YT223
USD8,350
