Steering arm spline
on my old Clark CY50 No. 03 W 2435 F ,
With engine off I can move the steering wheel 180 deg with no movement of the rear wheels. !
Adjustable rod ends are good & firm (2 rear slight,) & tie rod ends good. But the major contribution is a short arm that is attached to the top of a virtical spline in the rear center of the machine. The spline maybe worn & this arm moves both axially & radially on the spline shaft.
I am not sure what keeps the arm on the spline - Gravity ?, its a bit hard to get in & see.
Usually arms are clamped tight on a spline but I cant see a clamp bolt yet.
Does anyone have any ideas or info.
  • Posted 3 Sep 2008 12:38
  • By tonigau
  • joined 26 Aug'08 - 7 messages
  • Queensland, Australia
I ounces had this problem with an truck a wail back and found to be a combo of things that gear box at the bottom of the column I found the bracket that held it on had broke free from frame. u will need to jack up rear wheels and look down with a flash light with wheel cut al the way one way. Be careful block the truck up The gear box also has a adjustment screw on it to adjust free ply and gear smash. After that u will need to inspect the drag link there is a tie rod looking end and is actually a valve and ports oil and that is the HYD steering then check all 4 tie rod ends and spider and drag link ounces all that u shod had power steering again once all ply is repaird
  • Posted 4 Sep 2008 18:51
  • By dantheman
  • joined 4 Sep'08 - 18 messages
  • New Hampshire, United States
I should have mentioned that about 40% of the steering wheel play is the PowerSteering ram actuation, so when the motor is running the play is much less but still not real good.
I have degreased around the spline shaft & there is a C clip at the top that holds (stops it falling off is about all) the shaft on the spline.
Maybe the arm (female spline) could be slit & blocks with bolt holes welded on to make it clamp the shaft. This would require specialist welding being cast/forged.
  • Posted 4 Sep 2008 13:16
  • By tonigau
