steer link
how do you remove steer link on 40fctt-188
  • Posted 14 Nov 2008 01:39
  • By squidman
  • joined 12 Mar'08 - 23 messages
  • Rhode Island, United States
A bottle jack?...Sounds like it would work out alright. I've usually got the truck up on a lift, so I'd never thought about using a bottle jack. I did however have to lower the truck onto a long piece of 4x4 once to put enough upward pressure on the link. But that was in a wet application and it probably hadn't had grease in over a year :D.....Fun times.
  • Posted 6 Aug 2009 14:19
  • By griffman_23
  • joined 5 Aug'09 - 28 messages
  • Michigan, United States
--Just an opinion from some punk ruining the world--
I have used a bottle jack to put pressure on the link to get it to pop out of the steering knuckle. I like the idea of the chisel. Maybe a combination of both methods will help on a stubborn link.
  • Posted 6 Aug 2009 11:12
  • By Liftdoctor
  • joined 22 Jan'05 - 115 messages
  • Indiana, United States
Crown does sell the generic Fork Tool used to seperate the "dogbone" links in the steering, however there's a way around this without damaging the seals, however I'd recommend replacing them anyway.
If you Take the caps, cotter pins, and nuts off, Crank the wheel (start with the left) you should be able to fit a mid sized chisel between the steer link and the axle frame. Hammer it in tight to hold pressure, and give the top of the "dogbone" link a good wack with a large hammer. The shock should pop them apart without damaging the seals, and I've found works better than that Fork Tool (aka Pickle Fork).
Repeat on both ends of both sides (left and right) and then the steer cylinder is free from the Knuckles, and you don't have to remove the wheels either. If you have a lift this should be complete in around an hours time.
  • Posted 5 Aug 2009 14:05
  • By griffman_23
thank you tonymfg for information
  • Posted 18 Jan 2009 04:29
  • By squidman
oneshotmech@yahoo.com
crown has seperation tool for this specific job. Have done hundreds on the 50 fc's. dont forget to order seals. You are going to destroy the old ones.
  • Posted 16 Jan 2009 13:12
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
steer axle
  • Posted 22 Nov 2008 03:35
  • By squidman
Steer link? Are you referring to the steer axle,or the universal joint in the steer columm?
  • Posted 15 Nov 2008 10:13
  • By Truck_Tech
  • United States
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
SMV (Konecranes) 4632CC5
edition #1272 - 12 March 2026
In this week’s Forkliftaction News , we report on the three inaugural CEOs who will manage the new materials handling entity of Toyota Automated Logistics when it launches on April 1... Continue reading
Eldo Verhaagen Eldo Verhaagen
Sales & operations director – material handling & agriculture Benelux, GRI
Director, dealer development Midwest & Southeast, Big Joe Forklifts
Director, Cyngn
Vice president people Americas, TVH Americas
Director, Cyngn
Since February 2016, it has been against the law for grocery stores and supermarkets in France to throw away unsold or expired food which is still edible. Instead, it must be donated to food banks or composted.
