Steer Axel problems?
Has anyone heard of any issues that CAT has with Steer Axles on the DP70?
  • Posted 9 Feb 2006 07:05
  • By mark_k
  • joined 9 Feb'06 - 2 messages
  • British Columbia, Canada
uk term is nipple !
  • Posted 8 Dec 2007 07:51
  • By kevin_k
what is the meaning of zerts?
  • Posted 4 Dec 2007 16:21
  • By deepak_v
  • joined 4 Dec'07 - 5 messages
  • MAHARASHTRA, India
We have a DP50 which is the same as the Nissan F04G45UT's we have. There has been a modification done to the later models that has grease nipples and a re-designed bottom bearing plate. In the early models we take the bottom plug out and grease it through that, then replace the plug. In the later models the seals are also fitted different in order to keep the dirt out. The new bottom plates are different and are not retro-fitted to the older models. Probably worth turning the seals over we have not done this yet (but will on the next rebuild) if the axle is greased regularily in the older type.
  • Posted 30 Jul 2006 11:41
  • By Lifter
  • joined 27 Jan'06 - 6 messages
  • New South Wales, Australia
There are no known issues with the steer axle in these units. Are you havin spindle bearing failures? or Wheel bearing failures? If so, you need to disassemble and repack more often, or drill and add some zerts.
  • Posted 30 Mar 2006 14:57
  • By dan_selph
  • joined 4 Feb'05 - 5 messages
We are having an issue and are being told that it is due to the type of work and terrain that the forklifts are operating in. I have also been told that there is a known problem with the steer axels on the DP70's.
  • Posted 10 Feb 2006 09:32
  • By mark_k
Are you suffering with a problem or simply interested if there are known issues?
  • Posted 10 Feb 2006 09:23
  • By daniel_g
  • joined 13 Jan'06 - 83 messages
  • Flevoland, Netherlands
Taylor T520S
Autolift E180AT36B-D5-180
Taylor T520S
Taylor T520S
