Cat Lift Trucks (& Caterpillar) GC25:
Starts then dies immediately
Hi all, our forklift has been running fine except for some small leaks, had it serviced for LP leak repair, new tires, oil and filter, air filter. Mechanic ran it until LP was empty and then switched out tank for full one, now it won't stay running. Starts, then dies immediately. Sn# 4EM01364 I have to get it back working as we have a huge delivery next week! Help! TIA ??
  • Posted 9 Mar 2024 07:46
  • Discussion started by Twinmom
  • Arizona, United States
like Scott_ said, check the o-ring in the tank nozzle and the nozzle on the truck too. The one on the truck side has a dust ring that sometimes comes off and gets stuck on the tank side, then when you put on the new tank it gets in the way and will not allow the valves to open correctly.
Or it could just be something in the tank side of the valve, try another tank and see if that changes anything. Generally if there is any issues with the tanks it's usually leaking at those o-rings because they are not changed out and deteriorate causing the leak, but occasionally you'll find what i was explaining with the dust ring getting stuck on the truck side nozzle up inside it.
Other than that the only thing i can think of on these trucks that can cause starting issues is the lp converter freezing up or the little solenoid 'rattle' valve inline with the vaccuum lines at the converter, sometimes those go bad causing a start/run issue too. When you turn on the key it should vibrate.
  • Posted 11 Mar 2024 07:11
  • Reply by swoop223
Just a thought maybe when he took the empty tank off the oring that is in the valve on the tank fell out and now is in the rego valve on the truck unscrew the new tank and look to see if there is a o ring in the rego valve if so get a small pick and take it out or sometimes you can bang the rego on the counter weight and it will fall out it should be in the tank not in the rego valve. I havea call a least once a week that someone changed the tankand the truck wont start.
  • Posted 10 Mar 2024 08:22
  • Reply by Scott_
Scott
SMV (Konecranes) 16-1200C
UN Forklift FD30T-NJM1
Lift Technologies Inc.
UN Forklift FD35T-C2JB2
Terberg YT223
St. Louis, MO, United States
Jefferson, WI, United States
Johnston, IA, United States
