starts and goes directly into shut down
need help! i went on no run ,call the unit starts and goes into 30sec shutdown.let set couple minutes does same starts and shuts down but if as soon as it shuts down I try to start I get 3
interlocks hyd,seat,return to neutral,the strange thing is no codes.I'm thinking vsm any help and advice would be appreciated.and I would like to get a copy of fault codes @ trouble shooting for vx trucks
Thanks Smoken
  • Posted 7 May 2009 13:48
  • By smoken
  • joined 16 Nov'08 - 10 messages
  • Indiana, United States
smoken
There are over 3000 fault codes. The manual is 1400 pages. You need to contact your local dealer and purchase the manual.
  • Posted 19 Aug 2016 02:21
  • By BREWSKI
Hey Man, I have previously had the same issue. crank the truck and it immediately goes into engine shutdown. there is a sensor on the radiator without enough coolant the engine goes into shutdown.
  • Posted 19 Aug 2016 01:51
  • By Jeff33McGee
  • joined 19 Aug'16 - 1 message
-Jeff
quality product! happy days.
  • Posted 18 May 2009 06:18
  • By tugmaster
  • joined 25 Aug'08 - 73 messages
  • United Kingdom
tugmaster. i had that fault this very week on one of our own brand trucks. dodgy rear light replaced and update of vsm. sorted
  • Posted 16 May 2009 02:10
  • By kevin_k
check your lights are working.check the wipers work.if they dont the truck considers this a safety issue and shuts the truck down.
  • Posted 16 May 2009 01:08
  • By tugmaster
  • United Kingdom
scroll the up/down buttons on the dash.if it on 30 sec shutdown it should give you a reason
  • Posted 9 May 2009 03:14
  • By kevin_k
just a w.a.g.; key switch. bad contact on "run" position? shuts off fuel? that would explain "no code".
  • Posted 7 May 2009 20:40
