Starting Problems
Last week we went out to start our forklift and it wouldn't turn over. We did the obvious things we could think of, hooked up jumper cables from our big diesel truck, took out the starter and had it tested, and replaced the starter relay. But it still won't turn over. When we turn the key, we can get a clicking, but that's all. Not only that, but it has recently started making the clicking sound on it's own, with the key in the off position. No one here is really forklift savey, so any help would be great. The lift is a Clark model GPS25MB. Thanks.
-Dave
  • Posted 18 Jan 2006 03:25
  • By dave_t
  • joined 13 Jan'06 - 2 messages
  • Kentucky, United States
of course dont forget to check the ground to the engine if u have a mulitmeter see if u get continuity from the starter housing to battery negative and check for resistance there should be none (ohms)
unfortunatly thats a clark with a mitsubishi engine i believe a 4g52 or 54 (or is it 53 i forget offhand) ithink the same model with a continental has a different designation than "mb"
mitsu engines sometimes when the ring-gear or starter pinion go bad they wont engage with eachother and u get a metalic thud almost a click with some oomph
first try moving the ring gear to a different position by turning the crank pulley or the torque converter (i dont think that tranny has a port to turn the torque converter like mitsu's do with the same engine)
take the starter back out and get a new 1 call helmar they have cheap replacements (look up their 1800 #) sometimes this works with a new starter pinion and closely inspect the ringgear when u have the starter out (with a flashlight)
good luck
  • Posted 27 May 2006 16:16
  • Modified 27 May 2006 16:22 by poster
  • By justinm
That is a wonderful truck - there is a neutral switch after the ignition switch & a starter Relay also. Jump the starter solonoid from B+ then trace backwards most likely cause is starter relay.
  • Posted 25 May 2006 15:37
  • By FrankieW
  • joined 25 May'06 - 22 messages
  • British Columbia, Canada
FrankieW Technician
Maxlion FB30LI
Mobicon 2T
