Speech low
Hello, it is a Linde R14N-1, year 2014 , everything works but not drive fast, there is no error Message on the display. I checked controler plug connections and pot accelerator.I checked seat and handbrake switch, potentiometer, alternator, generator ,accelerator switch....., and the direccion indicator light works
Thanks
Please someone help me :)
Thanks
  • Posted 28 Oct 2024 12:42
  • By nguyen_t
  • joined 17 Jan'19 - 9 messages
  • Viet Nam
If its an 1120 it won't be 2014, if you installed a new potentiometer it will need calibrating.
You need to get a laptop plugged into it to diagnose the issue
  • Posted 6 Nov 2024 04:39
  • Modified 6 Nov 2024 04:41 by poster
  • By lifter01
  • joined 4 Jul'09 - 465 messages
Hello it is series 1120 , i checked all the altitude sensors and on the screen it does not show turtle running , i checked and replaced the speed sensor on the motor but now it only runs 2km/h
  • Posted 4 Nov 2024 12:01
  • By nguyen_t
  • Viet Nam
Check the micro switch on the brake pedal the ends do fail on them between the operating arm and switch, I've changed quite a few on the 115 reach trucks. This will give the fault you've described and not show an error on the dash
  • Posted 3 Nov 2024 23:09
  • By lifter01
Hello, how much slow speed you have? is it 1120 series?
If you have high mast, there is 8-meter switch which slow down the speed if mast is lifted more than that height. it doesn't show on display. there could be wire or sensor faulty. prior models had limit switch, and new ones are with proximity sensors.
if it moves very very slow less than 1 kph then it is RPM sensor on drive motor, wires also get too hot also.
  • Posted 31 Oct 2024 20:31
  • By Addy_MHE
  • joined 9 Jul'13 - 160 messages
  • Sindh, Pakistan
Work Until IDOLS become your RIVALS.
Hello did you checked brake pedal?speed sensor on traction motor?
  • Posted 30 Oct 2024 15:55
  • Modified 30 Oct 2024 15:56 by poster
  • By Evtech
  • joined 27 Sep'24 - 6 messages
  • Cyprus
Hunslet
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
May 20-21, 2026 - Melbourne, Australia
August 19-21, 2026 - Bangkok Thailand, Thailand
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
