Yale MPW040SAN12C2748:
Slow speed
This machine is not going into the second and third speeds. The contacts are good in the handle top and the contacts are in great shape in the motor compartment. What ohm's is the resisitor suppose to be next to the contactors-it is a fairly big resistor- i'm thinking it should be about 10 ohm's but not sure. I measured the resistance at the resistor when the drive wheel was off the ground at it was 5.86 ohm's at full throttle.
  • Posted 18 Feb 2010 21:29
  • Discussion started by ray_s
  • Alberta, Canada
Mitsubishi FGE35AT
Toyota 8FGC35U-BCS
Flesherton, Ontario, Canada
Jefferson, WI, United States
St. Louis, MO, United States
Johnston, IA, United States
