Sin potencia.
Buenos dias compañeros, el caso es que la maquina no tiene potencia, al iniciar la aceleracion en llano se mueve muy poco sin fuerza, al seguir acelerando salta la directa da un tiron y se para, al volver a acelerar inicia despacio sin fuerza, da otro tiron y ya se para del todo sin respuesta al acelerador, la bateria esta cargada y eleva con alegria. revisado los tiristores y dan como buenos, os ha pasado esto alguna vez? la maquina es vieja pero nunca ha dado problemas una buena maquina.
Gracias por vuestra ayuda.
Please use English language...Littoral translation...
Good morning colleagues, the fact is that the machine does not have power, when starting the acceleration on the flat it moves very little without force, when continuing to accelerate the direct jump jumps and it jerks and stops, when accelerating again it starts slowly without force, it gives Another pull and it stops completely without response to the accelerator, the battery is charged and lifts happily. I checked the thyristors and they look good, has this ever happened to you? The machine is old but a good machine has never given any problems.
Thanks for your help.
  • Posted 24 May 2024 16:29
  • Modified 25 May 2024 03:08 by administrator
  • By juanlao
  • joined 22 Jun'18 - 27 messages
  • islas baleares, Spain
Repair, not replace.
ok, thanks for the clarification, all in English.
Well, friends, the fault was in the power triristor, it worked but it did not deliver all the power, when you dismantle it you can see a burned part, now we have to see why!
  • Posted 28 May 2024 23:05
  • By juanlao
Toplift Ferrari TFC36-48
Stoney Creek, Ontario, Canada
USD1
UN Forklift FD20-35FJM3
Libiao Robotics
USD1
