Sideshift Difficulties.
Have two trucks (same ones as previous) that are having odd problems. The sideshift, with a load, will shift one direction fine; start back the other way, it works ok untill the operator stops. It then stalls there. It has to be shifted in the opposite direction slightly to continue. Carriage bearings and slides are ok, pumps have been replaced in an attempt to correct the problem, fluid and filters have been recently changed, and the carriage is shimmed ok. We're scratching our heads.
  • Posted 27 Sep 2009 01:28
  • By jeff_i
  • joined 2 Nov'08 - 15 messages
  • Iowa, United States
the one under the cover would be the best to start with.
  • Posted 9 Oct 2009 01:38
  • By JonG
  • joined 7 Nov'07 - 155 messages
  • United States
There are two manifolds on this particular machine; the main one under the hood and a second smaller one mounted on a standoff on the carriage. Would it be in the main block or the secondary, do you think?
  • Posted 6 Oct 2009 23:42
  • By jeff_i
i,ve had this on a linde truck mate. your valve section may have internal damage. remove the spool for the sideshift it may be damaged
  • Posted 27 Sep 2009 03:27
  • By kevin_k
Tusk 500PGH14
Kalmar-Ac P100CXD
Oxford Ct, United States
Tusk 500PGH14
Kalmar-Ac P100CXD
Hyster
Esie Cortez Esie Cortez
