Shuts down completely using Forward/Reverse or any hydraulics
Event codes stored are 303, 111, 313 and is messaging low brake fluid which i need to look into also. The parking e-brake switch is loose and doesn't rock completely into engaging the brake when parking. Sometimes the truck will move after turning key on and off. Some times the hydraulics will work if you use them while traveling. 9/10 times truck will just power down completely trying to use and controls/throttle.
  • Posted 18 May 2021 11:32
  • By john_johnson
  • joined 18 May'21 - 20 messages
Alright !
Glad to hear the good news.
Crown BDI's can be notoriously inaccurate.
  • Posted 22 May 2021 13:14
  • By LaGrange
  • Missouri, United States
Strong in mind, Strong in Health.
I tried my other crown's battery on it and it functioned correctly. Thank you very much for the help. I don't understand why the BDI on the display can be so high with that low of voltage. I'm charging up a spare for it right now.
  • Posted 22 May 2021 12:57
  • By john_johnson
miami, florida
The voltage came back 34.9v and when i plugged it back it was at 65% BDI -one cell slightly low but i filled it up
  • Posted 20 May 2021 05:02
  • By john_johnson
miami, florida
SC 4500's don't use Brake Fluid.
The Return Spring for the Brake Pedal might be stuck due to rust.
You can lubricate it with chain lube.
  • Posted 19 May 2021 13:12
  • By LaGrange
Thanks for the reply
I dont know if they are simultaneous. I just scrolled through the events back to event 15 and those were the only 3 on the list. The BDI said 100% when i loaded for transport maybe dropping to 80% after getting back and driving it across the building and testing it out a bit. I'll check the water levels and voltage tomorrow and swap the battery out with known good one if I can.
  • Posted 19 May 2021 13:02
  • By john_johnson
miami, florida
Have you tested battery voltage ?
I'll bet the battery is drained, way below 20% State Of Charge.
That many error codes at one time usually means very low voltage.
  • Posted 18 May 2021 20:35
  • By LaGrange
Alogotransiphobia is the fear of being caught on public transport without a book to read.
Taylor TE650S
Wellwit WMF1000
Shenzhen, Guangdong, China
USD50,000
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
