Shows 0% Charge batteries yet unit functions
Hey Boyz.....
My boss has asked me to look at several electric forklifts. Not my fortee.
This battery pusher has 24.7 volts after a full overnight charge....yet it shows 0% charge ??
Just wondering WTF....
Any help would be appreciated!
  • Posted 22 Aug 2014 23:21
  • By MickMike
  • joined 26 Feb'14 - 6 messages
I had the same issue. Having a 0 on the gauge prevents the forks from lifting but driving is ok. No codes. The battery is fully charged. for some reason, the circuit board stops reading the battery voltage. I replaced the circuit board in the arm and this fixed the problem. The part number is: TO 00590-47051-71
  • Posted 15 Jan 2015 00:27
  • By Rabbitt
  • joined 14 Jan'15 - 14 messages
Never too old to learn
If this is a 24v truck which i'm assuming it is.....
24.7v after an all night charge is not a good sign.
After charging a 24v system should be reading around 26 to 28v.
Do a load test on each battery if it has a battery pack with multiple batteries or if it has a single industrial battery use the hydraulics and load the system to see what kind of a load drop you have.
If testing single battery it shouldn't drop more than 1 to 1.5v, if the industrial type and it drops more than 4 or 5 volts under a full load in a 15 to 20 second loaded stall then you need new batteries.
Also plug the charger in and use a VOM and verify it is charging.
  • Posted 23 Aug 2014 02:16
The unit has a % charges display on the digital handle display. I am not sure if it is resetting it was operating normally about 6months ago
  • Posted 23 Aug 2014 00:25
  • By MickMike
Does the unit have a battery monitor.is it resetting. is it plugged in?
  • Posted 23 Aug 2014 00:22
  • By ray_j
  • joined 22 Aug'14 - 13 messages
  • Missouri, United States
edition #1303 - 15 October 2026
In this week’s Forkliftaction News , we report on a number of product launches including an Auto-Navigation Forklift Robot from Chinese equipment maker Leapting, developed for utility-scale solar construction sites... Continue reading
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
Cyngn launches automation subscription model Mountain View, CA, United States
The term 'Genuine Leather' is not used to reassure you that the product is made of leather, but rather to indicate that the lowest quality of leather is used.
