Setting cam timing Mazda 2.2
Changing the head on eh GLC050VX with the 2.2. How do I set the static timing on the cam sensor?
  • Posted 26 Jan 2021 03:40
  • By josh_gernentz
  • joined 26 Jan'21 - 5 messages
Thanks, I got it going
  • Posted 22 Mar 2021 20:34
  • By josh_gernentz
The cam gear has either abcd or 1234 stamped around the gear. There is an arrow in the top of the plate behind the gear. Align either the A or the 1 at the arrow. Make sure the number 1 piston is at TDC. Install timing belt and set tension. Rotate crankshaft by hand 2 revolutions to make sure timing marks are correct. The cam shaft sensor has a dot mark on the gear and the shaft. Align the marks together and install into head with the dot at the installation hole. Do not use the roll pin as a mark.
  • Posted 19 Mar 2021 23:53
  • By Fishmech
  • Virginia, United States
