the brake is fine. How can I test the speed sensor, it is the one on the motor shaft located under the bearing? I sent you a photo to your mail. Colombia is located at north of south America, between Panama, Venezuela, Ecuador, Peru and Brazil.
Thanks for your help.
Original post deleted...
Forkliftaction does not condone the selling or trading of propriety information including authorization codes or any other dealing of copyrighted material by unauthorised persons. Any correspondence about illegal activities on our forums could put you in breach. Forkliftaction would be obligated to pass your contact details to police authorities if they were requested.
Please do not post these types of material on our forums again.
Thanks Geroj for your help.
Finally I could disassembly the drive motor but this model has AC system for this drive motor, and the fail is when I push the accelerator, the machine runs very slow but there is no fail code on the display and the wires heat up faster than normal.
I checked the transmission to see if there was any lock in the transmission and to see the bearings but everything it's OK with them, so what else can I do?
thanks.
my Mail is alejandroherrera at gmx dot com.
Thanks in advance Gerom.
Ya quité el electrofreno y los tornillos y lo hale hacia a rriba pero no se mueve, por eso pensé que tenia algun tornillo del otro extremo de la transmisión y que tocaba desarmarlo desde abajo.
Se requiere halarlo con algun dispositivo?
Gracias Joram.
En el manual de JH no viene nada, pero es sencillo, quitas el electrofreno, sueltas los tornillos que van abajo en el motor y a tirar para sacarlo, si el inducido , visualmente está bien, Yo solo cambiaria escobillas.
