S50FT Overheating Issues
I've got a Hyster S50FT (S/N F187V22195K) equipped with the Mazda 2.2L LPG engine and Duramatch transmission that is having overheating issues. The lift runs fine most of the day but towards the end of the day it tends to rise in temperature and set off the powertrain protection system and shut the engine down. I have verified with a temp gun the engine temp is rising to the 250° mark that shuts down the engine so I don't believe its a bad temp sensor. The thermostat has been replaced, water pump replaced and verified to be moving water through the system. New head gasket relatively recently replaced. Radiator fins are cleared of debris and fan spins good. Even pulled the cat and checked the exhaust to make sure there were no clogs causing excessive heating there either. Any ideas on what would cause this overheating?
  • Posted 1 Jun 2024 06:27
  • By BHF_SAF
  • joined 1 Jun'24 - 1 message
  • Arizona, United States
Scott,
Did you find the problem? Will all that has been replaced and tested, have you noticed any leaks? Do you have to top off anti-freeze every couple of days? If cleaning the radiator does not work, make sure the proper mixture of anti-freeze is used. A new rad cap would not hurt. Let us know what fixed the problem.
  • Posted 11 Jun 2024 22:46
  • By Fishmech
  • Virginia, United States
Sounds like you checked alot l would pull radiator and send to radiator shop to check for correct flow it only takes about 20 % of core to clog to cause truck to run hot over a long period.
  • Posted 2 Jun 2024 08:20
  • By Scott_
Scott
